P0300/ vac leak
Old Mar 30, 2008 | 02:43 PM
98gstspy's Avatar
Default P0300/ vac leak
ok my car just threw this code how do i fix it and what causes it? one thing is i know i have a vac leak somewhere-how much would a shop charge to fix it? and what is the reason i am throwing this code?
Old Mar 30, 2008 | 02:46 PM
Default RE: P0300/ vac leak
Its not a vac leak, its a missfire.
Plugs or wires, change em up with NGK Classics and Mitsubishi spark plug wires.
Old Mar 30, 2008 | 02:47 PM
98gstspy's Avatar
no what i am saying is that my car has a vac leak. i hear a hissing sound and it runs like crap, i just cant find where it is. so wat would it cost to get it fixed?
Old Mar 30, 2008 | 02:50 PM
The hissing sound is more than likely from the intake, somewhat normal.
I just told you what the problem is.
If for some freak chance that it actually is a vac leak, it would cost how ever long it takes to find the leak. Im 90% sure that its not that.
Old Mar 30, 2008 | 04:26 PM
98gstspy's Avatar
well would that cause my car to have a hard time holding an idle to, its also hard to start when i first start it up/cold start.
Old Mar 30, 2008 | 04:50 PM
tjbiker031's Avatar
i would do what Sebba said first he might be right....but if you think hes lieing or dont know what hes talking about, do a boost leak test
Old Mar 30, 2008 | 04:55 PM
98gstspy's Avatar
the only reason i keep asking is because of how it idles. its not timing it is dead on.
Old Mar 30, 2008 | 05:03 PM
TheAdvocate's Avatar
it will run like crap if its a big enough leak.. I would personally try finding the leak first then see if it gets better.. It could be just running to rich and foul the plugs out.. So even if you replace the plugs it could just keep happening..
Old Mar 30, 2008 | 05:22 PM
My moms GST had fried plugs and toasted wires and wouldnt idle.
If the boost leak was that bad, then you wouldnt be able to go past a certain RPM. Like a barrier.
Old Mar 30, 2008 | 08:48 PM
98gstspy's Avatar
its not a boost leak its just a vac leak some where i think. but i was reading in another page that a vac leak would cause these simptoms 2 that is y i think its a vac leak. i will try the plugs first
