Please read my last?
Old Feb 5, 2008 | 07:51 PM
  #21
hawwk11's Avatar
Default RE: Please read my last?
ORIGINAL: TheEngineer
Yea that sounds like a clutch to me. You might be able to jsut adjust the clutch to make it alittle better for the time being.
Thanks, alot. Any chance you know how to tel if its the slave, and or master cyl? Someone was telling me it may be that and if the car jerks, or stallsor somethin' it may be one of the three, clutch, master, or slave. Any input on this?
Thanks,
Old Feb 5, 2008 | 08:03 PM
  #22
well if its the master cylinder you can look under the steering wheel and it may be leaking where the clutch rod goes into it. Also you could check to see it there is adequate fluid in the resevior and also it could be that the system needs to be bled.
But the easiest way to check if the clutch is really going is go slow and put it into third gear, then floor it and the rpms will slowely go up. If you get to around 4k-5k and the rpms really fly up and you dont feel any power then the clutch is slipping and is worn
Old Feb 5, 2008 | 08:24 PM
  #23
hawwk11's Avatar
Thanks, alot Engineer
madmat
May 7, 2022 10:50 PM
Vo6
Jul 13, 2005 03:39 PM
vertstanggt
Mar 15, 2005 06:46 PM
Boxy458
Jul 2, 2004 04:04 PM
captain_kickass
May 31, 2004 09:18 PM
