please read and respond!!
Old Mar 27, 2007 | 05:21 AM
Gstfat's Avatar
Default please read and respond!!
i heard earlier in a forum that dsm's dont like iridium spark plugs,i have a 96 gst and one guy said i should take out the iridium and put regular ngk spark plugs,and he also said the factory ignition wires are the best, is he right?! please help im confused a little bit,my car is missfiring i wanna know why.,could this be the case, cuz i have iridium and 9.3 ml ignition wires what should i do , please say everything you know
Old Mar 27, 2007 | 06:19 AM
2nd g eclipse gst's Avatar
Default RE: please read and respond!!
i would deffinatly change them to regular ngks
Old Mar 27, 2007 | 10:10 AM
even though i know they are supposed to be pre-gapped, check the gap. If thats fine then it may be the spark plugs
Old Mar 27, 2007 | 10:38 AM
Dude there are so many of these posts going around its not even funny.
You dont have to change back to the OEM wires but they are the best. But the iridiums have to go.
Old Mar 27, 2007 | 10:42 AM
Dusty Eclipse's Avatar
Its true, theres quite a few of them on club3g.com too.
Old Mar 27, 2007 | 10:51 AM
soundcolor's Avatar
as far as the plugs go, alot of people say iridiums suck on DSM's, but I dont know. change'em and see if it helps..
as for the wires.
The factory wires are good, by far not the best, but they are good.
The best, well, that tends to be a subject of much debate.
I like Nology... but MSD, Taylor, (some) Accel, or Magnacor. Generally, with a stock factory ignition system, the factory wires work as good as anything else. Start modding the ignitioin system with those nifty MSD systems, and they send more spark than the factory wires can handle. So change'em.
Generally, the only time you are going to want to run a larger wire/aftermarket wire should only be a fewreasons, Either you have to run your wires close to something realy hot for whatever reason, and need a wire that wont melt, or you have stepped up the rest of the ignition system, and dont want any interferance either going into, or out of the wire itself... Or, last but not least, you are fixing up the ignition system, and want all the power the coil is sending to find its way to the plug...
If you havent done anything to your clipse, then your fine...
Old Mar 27, 2007 | 11:05 AM
Any idea if Nology makes wires for the 3G?
Old Mar 27, 2007 | 11:51 PM
soundcolor's Avatar
Yes, they do, here is the link of where to buy them, scroll down the page until you find the Mitsubishi section, its the very first one on the list.
http://store.racinglab.com/nologyhot...FQM6gQod-kSuQg
here is the link to Nology's homepage, they have some cool videos, and descriptions of how, and why they work...
http://www.nology.com/
Old Mar 28, 2007 | 12:43 PM
RCJr9186's Avatar
[sm=jawdrop.gif]my God... Soundcolor actually posted something worth reading... a-freakin-mazing
Old Mar 28, 2007 | 03:23 PM
I see your taking over my throne as site ******* : ) im so proud
