polyurethane motor mount insert
anyone know where i can buy them individually?and are they easy to install?
RE: polyurethane motor mount insert
far as i know you can just buy them all 4 for front/rear or drivers/passengers. they easy to install, the go over your rubber mount, BUT if its torn you cannot put it on there, you gotta buy a new mount and put the insertover it. each mount its 3 bolts and pretty much like changing a mount. but the rear is a little harder to get out then the front.
you can also get the prothane which completely replace the rubber in the tranny and timing belt mounts. If you get them let me know and I'll tell you a trick for the rear mount
