polyurethane motor mount insert
Old May 13, 2008 | 09:43 PM
Gstfat's Avatar
Default polyurethane motor mount insert
anyone know where i can buy them individually?and are they easy to install?
Old May 14, 2008 | 08:59 AM
tjbiker031's Avatar
Default RE: polyurethane motor mount insert
far as i know you can just buy them all 4 for front/rear or drivers/passengers. they easy to install, the go over your rubber mount, BUT if its torn you cannot put it on there, you gotta buy a new mount and put the insertover it. each mount its 3 bolts and pretty much like changing a mount. but the rear is a little harder to get out then the front.
Old May 21, 2008 | 10:10 PM
oh_what_up's Avatar
you can also get the prothane which completely replace the rubber in the tranny and timing belt mounts. If you get them let me know and I'll tell you a trick for the rear mount
Arpmeister
1st Generation
Apr 13, 2010 11:13 PM
Gstfat
Jun 11, 2007 10:10 PM
timot
1st Generation
Mar 21, 2006 03:14 AM
shiznit013
Oct 11, 2005 12:45 AM
pc
Mar 20, 2005 05:43 PM
