Problem? Air? Oil? Exhaust?
Old Nov 12, 2006 | 06:27 PM
silvercoupe97's Avatar
Default RE: Problem? Air? Oil? Exhaust?
Do you have a 1g or 2g or should I ask if you have an MHI or Garret turbo? Is your bov recirculated or do you have it vented to atmosphere?
Can you track down where the oil is possibly coming from?
Old Nov 13, 2006 | 01:40 AM
agallardo's Avatar
I have a 2nd gen. I have an EvoIII Big 16G. The oil seems to be around the BOV. But today, I jacked it up and notice alot of oil around the intercooler. So today, I did and oil change and while i was on it, decided to do spark plugs and wires, because it was due in a little bit. Anyway, i also cleaned out the intercooler with gas. I took it for a spin, it did it at first but eventually it spooled up fine. The oil i found in the intercooler wasnt a little bit, it was ALOT! The the normal kind of oil found. But damn, definitely alot. Anyway, I let it cool down and took it for another spin and it was still fine. I hope that was it. I guess i will find out tomorrow. But what would your guess be? What do you think it is? Its a month and half old turbo. It has no shaft play. Its pretty much brand new. My guess, is the fact that the stock SMIC is too small. I am planning on the FMIC next. What do you think?
Old Nov 13, 2006 | 03:26 AM
racerx55's Avatar
the rattling & exhaust restriction could be the cat coming apart , chunks of it getting stuck then flying out .... if you still have it on that has no explanation for the oil tho
Old Nov 13, 2006 | 09:49 AM
agallardo's Avatar
So anyone know whats up with the oil? I cleaned out the SMIC and the intercooler piping. Nothing? Still does the same thing. I found oil around my BOV again after taking it out for a drive... PLEASE HELP. This is killing.
Old Nov 13, 2006 | 10:16 AM
Check your intake tube, the one before the turbo, and check it for signs of oil. You need to trace the origin of the oil. This will involve you taking all the intercooler piping off. There's no other way around it. I believe that the oil is coming from the breather valve (the tube coming from the left side of the valve cover) and making it's way down the intake, through the turbo, in and out of the intercooler, out of the bov (during blow off), then making it's way into the intake manifold and finally into the chambers. Do you notice puffs of smoke out of your exhaust? It's not a lot of oil, it may not even show, but still need to ask.
So, again, there's no other way around taking the IC piping off and tracing it back. Where else can that oil be coming from? Perhaps the turbo seals, but you said that it's pratically brand new! There's no other way that oil can get into the intake tract....is there? No, there is only two ways oil can get into the intake and I just mentioned them. It's not that hard bro, you just have to make sure you tighten everything back up real good and boost leak test it afterwards.
Here's a great write up on how to do a boost leak test on a Honda forum of all places and done on a 2g of all things.
http://honda-acura.net/forums/showthread.php?t=148666
Gotta love DSMs
Old Nov 13, 2006 | 10:50 AM
agallardo's Avatar
Thats what I did yesterday. I took off the intercooler piping and clean it all. Yes i did find oil in the intake pipe. I also found it in the lower intercooler piping, intercooler, and upper intercooler piping. Even a little on the BOV. So the oil was found starting at the throttle body all the way to the turbo, and some on the intake. BUT, i cleaned it all out. It still does it (it seems like something is clogged and just not letting the air push out). I drove it back to school and at first it spooled up fine, but towards the end of my journey, it started to do it again. I popped the hood and found some on the BOV again. It spools, but not til like 4500 rpm. It should be spooling at least by 3500. Thats the weird thing. DOES this help?
Old Nov 13, 2006 | 10:58 AM
Get one of those small fuel filters that have two hose nipples on each end, cut your breather valve hose in half, and put that filter inline.
Next, buy a new PCV valve (do not tighten it down hard or you will crack the valve cover!) and let us know how that works out.
Oil in the intake tube (the one that connects to the filter and turbo) is a sign that oil is getting in from the breather valve, which could mean that you have blow by issues or that the PCV is clogged or stuck open and is allowing pressurized air into the valve cover. From that pressure, it needs to go somewhere.....the intake tube and down the intake tract.
Does that make sense to you?
Old Nov 13, 2006 | 11:29 AM
agallardo's Avatar
Yeah.. Thanks man. By the way how much is a PCV valve? Where is it located exactly?
This might help me out? Look: http://members.shaw.ca/dsm.1000q/Eng...sual-index.htm
Where is it on there?
Old Nov 13, 2006 | 12:07 PM
Old Nov 13, 2006 | 12:49 PM
RCJr9186's Avatar
not sure where exactly the oil is coming from but a way to filter most of not all of it out is a catchcan, i'm sure you know this already. they are not very expensive and not hard to hook up at all!!! i'm relatively a novice at engines still but i've hooked 2 of them up. i would get this before you get your FMIC and new piping to ensure that it stays clean (or as clean as it can be).
