problems shifting into gear
Old Jul 21, 2011 | 11:36 AM
mexicanman's Avatar
Default problems shifting into gear
i have 99 2.0 non-turbo gs with hydro clutch and while at work i noticed i started having difficulty shifting into gears. i pull over and check the clutch fluid to find that it is empty so i filled it up and there wasnt anymore problems that night. the next morning however when i went to start her up there was barely any pressure on the clutch pedal but she still started up just fine and when i tried shifting into reverse there was resistance and the car started to move a tiny bit, the same happened with first gear. i can manage to shift into gear but it is difficult, there is no grinding noise when i do so. my best guess is to bleed the lines because air got into them. i just need to know what else might cause this to happen
Old Jul 23, 2011 | 02:46 AM
mxmikie's Avatar
replace the slave and master cylinders
newoutlanderfan
Apr 28, 2013 08:49 AM
shawark
Jun 2, 2008 07:46 AM
n0c7
Apr 14, 2008 06:15 AM
and2y105
Jan 31, 2007 12:33 AM
glenn
May 13, 2004 04:46 PM
