question plz help!!
Old Nov 23, 2007 | 11:17 AM
solina08's Avatar
Default RE: question plz help!!
15 psi. another question is it better to put ur bov in soft or hard with a 16g turbo?
Old Nov 23, 2007 | 04:23 PM
theinnereffect's Avatar
at 15 pounds itd be around medium you want to not be able to hear the bov on vacuum you should only hear it when your boost gauge shows your actually boosting just have it on soft and work your way up tightening it till you can not hear it on vacuum only on boost then your set otherwise if its too soft your running rich and if its to hard its compressor surge
Old Nov 24, 2007 | 01:31 PM
Basic things needed to run 16g to max potential.
Exhaust
Intake
BOV (recirculated)
Injectors (between 550 and 660cc)
Apexi SAFC II
Boost Controller
Boost Gauge
Wideband O2 Gauge
Front Mount Intercooler
Walbro 190lph Fuel Pump
After you tune the SAFC (really easy) you should be able to crank it up to about 23psi, and enjoy : )
I know you have a few of these things already, so dont worry. Just out of curiosity, where did you get your FMIC and the rest of your parts?
Old Nov 25, 2007 | 08:05 PM
Gstfat's Avatar
everyone knows where sebba is going with this....even if it is from ebay who cares, it works!!!!
Old Nov 25, 2007 | 11:26 PM
Shut up lol..
Dont ever buy **** from ebay
Old Nov 26, 2007 | 05:29 AM
TheAdvocate's Avatar
It wont do anything without a boost controller.. Because your car will run at stock boost (9-12) no matter what you have done to it without a controller.
Old Nov 26, 2007 | 06:13 AM
try and do some research. Most of this stuff has been talked about plenty of times before
Old Nov 26, 2007 | 09:20 AM
solina08's Avatar
okay for sure thanks for all the advice guys.....
xp8ntballkid309x
Dec 26, 2007 06:57 PM
xp8ntballkid309x
Dec 26, 2007 01:19 PM
newguy2007
Sep 27, 2007 08:05 AM
ketan2006
Mar 20, 2006 06:56 PM
eclipsegsx95
Feb 19, 2004 05:04 PM
