questions guys???
Old May 14, 2007 | 12:48 PM
katinkid's Avatar
Default questions guys???
well as some of you know i had to get my car running again because of the camshaft sensor and a busted cam sprocket pin???
now the mechanic replaced all belts, timing, etc.
replaced the pin and the sensor.
and also replaced the seals in the cams and camshaft.
$656 wow
now when I drive it, it drives and boosts excellent.
but if i take it over 4k in first and secon, i can here this whine coming from the engine, "when it pretty much starts to boos" sounds like its coming from the belts not sure. and it doesnt sound like a turbo spooling.
could my belts be rubbing. or are he just breaking it?
or could it be the seals whinning?
Old May 14, 2007 | 01:09 PM
Default RE: questions guys???
You turbo is toast : )
Take your intake off and wiggle it side to side and in and out. VERY little side to side is normal.. anything else is not .
Old May 14, 2007 | 01:34 PM
i agree with sebba, it sounds like the infamous turbo death whine
Old May 14, 2007 | 01:55 PM
Dusty Eclipse's Avatar
lol, banshee turbo.... Sounds shot
Old May 14, 2007 | 02:46 PM
RCJr9186's Avatar
got any cash left from the work you had done? for about 1500-2000 you can do a 16g install...
Old May 14, 2007 | 03:52 PM
For 500 bucks you can do a 16g install! Used turbo = 350+install kit = 400.
Old May 15, 2007 | 12:05 AM
katinkid's Avatar
sorry guys, i highly doubt its the turbo.
it def sounds like its coming from the belts, like something is rubbing together.
does not sound like a whinning turbo. i know what that sounds like from the rx-7.
car boosts excellent. very strong and responsive.
is there anything to check the turbo just to make sue???
Old May 15, 2007 | 12:46 AM
katinkid's Avatar
well i just drove it and maybe it is my turbo.
it increases gradually and decreases gradually with rpm's
so how long do you think i have if i just started hearing it???
a couple months please???
Old May 15, 2007 | 12:54 AM
50ul }{4ck3r's Avatar
DAM SUCKS
Old May 15, 2007 | 07:01 AM
sebba told you how to check it. Take off the intake and play with the shaft and see if it has any side to side or in and out play.
