quick question
Old Feb 23, 2009 | 09:11 PM
Gstfat's Avatar
Default quick question
Hey guys heres a quick question? I have a tick in my motor(I think it’s the lifters)heres my question how hard is it to replace the lifters? and I use Mobil 1 10-30 full synthetic. with a k&n oil filter. I heard if you use the oem filter the tick goes away. Does the egr valve have anything to do with the tick, cuz my car throws out the egr valve code and that the only code my computer throws. Please let me know asap Thanks, the sound is annoying
Old Feb 23, 2009 | 09:50 PM
dsm1990gsx's Avatar
Just replace the lifters w/ the 3g revised lifters, they arn't ahrd to replace. Check out www.vfaq.com, it shows how to remove and clean them.
Is your egr valve blocked off?
Old Feb 23, 2009 | 10:18 PM
Gstfat's Avatar
yeah i know about switching to the 3g lifters and no the egr is not blocked off,but changing the lifters i wont have to put the car back on timing or anything like that
Old Feb 23, 2009 | 11:23 PM
Honestly, it is normal. Just make sure you changed your oil when you should and you will be fine.
If you really want to get rid of it, then change them to the 3g revised. However, I don't think it is money well spent.
Old Feb 24, 2009 | 06:43 AM
And no the EGR has nothing to do with the lifters. Your egr valve may be clogged or stuck if its throwing a code
Old Feb 24, 2009 | 06:49 AM
dsm1990gsx's Avatar
If you read the write up on www.vfaq.com, you would know timing is not messed w/
Old Feb 24, 2009 | 08:14 AM
Old Feb 24, 2009 | 05:58 PM
theinnereffect's Avatar
try a different oil, I ticked pretty bad with mobil one but tried royal purple for the hell of it and it completely went away.
Old Feb 25, 2009 | 08:22 AM
Gstfat's Avatar
i guess ill go back to rayal purple and see what happens,but the question was are the lifters pretty much right there once i remove the valve cover?
Old Feb 25, 2009 | 09:08 AM
YES, once again look at the FAQ
92vr4
May 14, 2005 02:46 PM
newEclipse
May 9, 2005 11:59 AM
Cos
Apr 26, 2005 05:50 PM
Dyno_Man
Dec 28, 2004 05:14 PM
Luv Jones
Sep 9, 2004 08:54 PM
