racing???
Old Feb 24, 2006 | 04:47 AM
jroc1012's Avatar
Default racing???
while racing going into 4th gear my car pulls back like it is in 2nd gear. what could be the reason for this and do you think i need to replace the clutch or just shift into 5th? my car is a gst and im not sure on the turbo size b/c it was upgraded when i bought it and it doesn't say on the turbo what size it is the only numbers on the turbo are f2211. and if anyone has ever had this problem what did you do to fix it.
Old Feb 24, 2006 | 09:38 AM
slow420a's Avatar
Default RE: racing???
That wouldent be a clutch problem, going that fast you have to look at other places to find your problem, in that gear you should be over 80(past 3k) so I would make sure you have v rated tires, also areodynamics play a role in that to, a car can only go so fast.
Old Feb 24, 2006 | 10:18 AM
Sanguinius's Avatar
Yeah what speed were you going when you tried shifting to 4th, and what were your RPMs reading when you shifted into 4th and dropped the clutch? Did the engine wind up or did it stay at the lower end of the tach? Are you sure you didn't merely accidentally shift into 2nd instead of 4th?
Old Feb 24, 2006 | 05:49 PM
jroc1012's Avatar
When going from 3rd to 4th the RPMS were at 5500. As for the engine it wound up, and I am pretty sure I didn't accidently go into 2nd because it did it twice. Thanks for your replies
Old Feb 24, 2006 | 07:58 PM
ORIGINAL: jroc1012
It sounds like a 2nd gear slip up to me. Your not going to do that if you hit 4th gear. Kinda strange...do you have an aftermarket shifter?
Old Feb 24, 2006 | 10:41 PM
slow420a's Avatar
wow.. i so misinturpeted the post....
I bet a dollar you have a short throw shifter, my car does the same thing for 5th and 3rd.
Old Feb 24, 2006 | 10:42 PM
ORIGINAL: slow420a
that is what I was getting at... short throw it happens all the time. I met a kid who did it going down a track stuff 2nd instead of 4th and BOOOM blew his built up SR20DET and trash the who thing
Old Feb 24, 2006 | 11:08 PM
slow420a's Avatar
I saw the same thing with a ls1... poor poor car.
Old Feb 25, 2006 | 09:23 AM
Its def not all that uncommon with a shorty shifter. that is why I stck with my stock one. plus a shorty would be a long reach in the EVO.. it already is a long reavh
Old Feb 25, 2006 | 04:19 PM
Sanguinius's Avatar
That's one thing I love about my sentra. It won't LET me drop it down into too low a gear. It has interlocks so that like if I'm doing 30 MPH it physically blocks my from dropping into first.
hillcityracing
Jan 19, 2004 02:51 PM
hillcityracing
eclipse2gnt03
Nov 20, 2003 06:24 AM
eclipse2gnt03
Aug 1, 2003 02:33 AM
eclipse2gnt03
Aug 1, 2003 01:29 AM
