RATTLING WINDOWS
Old Jul 1, 2008 | 09:29 PM
ukrkoz's Avatar
Default RATTLING WINDOWS
ok, last thing i need to know on my son's 95 eclipse.
driver side window rattles mercylessly every time we shut the door. it's like something's totally loose in window guides, or something.
we are planning on long weekend repairs - swap oil pan, bumper, headlights, might as well take care of this too. window moves back and for a lot. anyone had same problem and knows the cure? or they are just made that way, as both windows do same?
Old Jul 1, 2008 | 09:53 PM
98gstspy's Avatar
Default RE: RATTLING WINDOWS
the window on my spider has a rattle sound but not like you are explaing. sounds like the track bolts are loose to me.
Old Jul 1, 2008 | 10:03 PM
itsme71190's Avatar
roll window down.take off door panel. take out speaker. inside the speaker hole to the right ull c the track. on this track ull c a brass bracket. thats ur problem
tjbiker031's Avatar
Click herethis may help alot, the pic are gone but it should explain what to do.
Old Jul 2, 2008 | 12:48 AM
sk8dudety's Avatar
yea thats a normal thing to have on an eclipse. there's a plastic piece thats inserted into that metal bracket he mentioned, all you need to do is get a pair of pliers and (without breaking the window of course) squeeze that bracket a little tighter onto the window and that should help a lot
Old Jul 2, 2008 | 07:35 PM
silvercoupe97's Avatar
ORIGINAL: itsme71190
That is correct. That part receives the most vibration for obvious reason and thus, it will loosen and rattle.
Here's a how-to on removing the door panel. It's a bit easier on the eyes... Door Removal.
Here's a real good how-to from D S M T a l k.
You will have to type that in the address bar (substituting the asterisks) ... or not, I just tested the link and it comes up just fine ... weird.
Old Jul 6, 2008 | 02:17 PM
Zfred10's Avatar
yeah my spyder window rattles a lot too...i took off the panel and everything was alrite. cant do anything about it
Old Jul 8, 2008 | 04:28 PM
757eclipse's Avatar
trust me i have the same prollem. i got if fixed at an auto repair place when i couldnt get it to stay myself and it still rattles
Old Jul 8, 2008 | 06:07 PM
ORIGINAL: 757eclipse
Try the things listed above and you should have better luck. Don't leave it up to a shop. Most of us have done it ourselves and have had no issues.
Old Jul 8, 2008 | 06:16 PM
Kaede.Noir's Avatar
Wow... i didnt think that could be fix! thnx for the link... im also gonna try the foam suggestion this guy gives there
