Remote
RE: Remote
I work at a dealership...here ya go.....First, insert the key into the ignition. Next, WITHOUT STARTING THE CAR, turn the key from the "off" position to the "on" position and keep cycling it like that about 6 or 8 times. Then hit the "Lock" button on the key f.o.b. (remote). If it cycled through properly then you will here the doors lock and then unlock and that will tell you that it is programmed. If it didn't work then just try it again cuz sometimes they are a pain in the azz!
