respone
Old Feb 22, 2008 | 01:42 PM
gmarc68's Avatar
Default respone
i have a 97 dohc 2.0 n/a manual. while driving i step on the gas to speed up and it takes about a second to really move. and it makes some weired noise like if im engine breaking but i hapens when im doin like 60 and attempt to pass someone, it will studder for a second. wat could it be? i have recentely had the injectors cleaned. maybe fuel filter?
Old Feb 22, 2008 | 01:52 PM
pilsenblue's Avatar
Default RE: respone
Maybe you should try a lower gear.Don't be in5th at 30mph uknow.0its anRS right? Not much power.if your running higher rpm it should pick uop better
Also add an intake! It really help with the power in lower rpm.s not as much studdering
Old Feb 22, 2008 | 02:01 PM
bestwiseguy's Avatar
Default RE: respone
Try changing your sparkplugs and wires.
Old Feb 22, 2008 | 02:03 PM
gmarc68's Avatar
Default RE: respone
i do have an short ram intake and i had a tune up last month. but like how you said being in 5th at 30mph is more or less how it sounds but only wen i try to pass someone.
Old Feb 22, 2008 | 02:07 PM
Default RE: respone
so your car feels like it has no power even in lower gears. does it just feel bogged down or is it jerking any.
Old Feb 22, 2008 | 02:11 PM
gmarc68's Avatar
Default RE: respone
it does feel like it lost some power. it does feel bogged down. if i down shift and hit a high rpm then i can floor it like usual but if im driving regular it feels like it hasnt got anything. I was thinking it might have been the gas i put but its the usual. regular.
Old Feb 22, 2008 | 02:34 PM
Default RE: respone
Change the plugs and wires!
Old Feb 22, 2008 | 02:47 PM
gmarc68's Avatar
Default RE: respone
i did last month i have NGK
Old Feb 22, 2008 | 07:18 PM
Default RE: respone
How old are the wires
Old Feb 22, 2008 | 10:13 PM
bagaak's Avatar
Default RE: respone
my toyota paseo had the same symptoms... but i looked at the dipstick... and viola... no oil.... put in oil and back came the power
