RIM SIZE!
Old 03-11-2008, 08:54 PM
Zfred10's Avatar
Default RIM SIZE!
ok now that i know that these rims will fit. any suggestions on which i should get? The first is the Drag DR-9, the second pic is the Drag DR-19's then the Drag DR-25's. LEMME KNOW PLEASE
ALSO TELL ME WHAT YOU RECCOMEND IN SIZE 17's OR 18's????
[IMG]local://upfiles/16355/F664C434B0EC40E19575E7125FE044E2.jpg[/IMG]
[IMG]local://upfiles/16355/564C30DFBD1A41DCBE0A70CF6196FDF9.jpg[/IMG]
[IMG]local://upfiles/16355/042EEDE000C746D3BFA7FE4080DDE378.jpg[/IMG]
Old 03-11-2008, 10:18 PM
Eclipze's Avatar
Default RE: RIM SIZE!
Get the first one...Drag DR-9
Old 03-11-2008, 10:32 PM
18's and the first one.
Old 03-11-2008, 10:33 PM
Jarreddl's Avatar
17 and the first one
Old 03-11-2008, 10:46 PM
lhausi2's Avatar
i like the 1st ones, and if you get 17's you'll regret it, so i say get 18's
Old 03-11-2008, 11:05 PM
Zfred10's Avatar
yeah but ive been reading a lot on 18's and bending. plus the area i live in isnt highways everywhere. there are some rough roads. Also i hear 17 is a smoother ride. ill get low profile tires to make them look good
Old 03-11-2008, 11:33 PM
Rob's Avatar
Rob
Rob is offline
#1 in 17's.
Old 03-12-2008, 01:58 AM
sk8dudety's Avatar
i vote #1 in 18"s... i used to have them on my old rs and loved them, plus i live in the country and in the city (when i'm at school) and the roads are pretty banged up here... the only reason why the 17's would produce a smoother ride is cause of the increase in tire size, but it isn't going to be that noticable... either way with bigger wheels and low profile tires your actual tire height will be exactly the same as the stock ones... the 17"s will just give you a bit more tire... but the 18's i've always thought have looked the absolute best on the 2g's
Old 03-12-2008, 02:27 AM
The one you like and 18's.
If you are worried about the rough ride get 17's and a taller tire.
Mine has 18X7.5 and drop springs.
[IMG]local://upfiles/13708/952CE90F4867431983320C2DB620A13A.jpg[/IMG]
Old 03-12-2008, 06:46 AM
sk8dudety's Avatar
i still dont think that he'll notice a difference in ride quality between a 17 or an 18, and if you're that picky get a 15" rim with a huge tire
Quick Reply: RIM SIZE!
