Rims rp07's 18x7 Will they fit?
Old Feb 23, 2005 | 09:05 PM
Angel_408's Avatar
Default Rims rp07's 18x7 Will they fit?
Haha Will I just might have done something dumb here, I've always liked the style of theses rims, so when i saw them on ebay for hella cheap I instantly bidded on them! Thing is I didnt check out exactly what correct size my 97-gs-t can handle *Dumbass*. But yea anyways I know you can put 18x7.5's on them but what about 18.7's? <----you guys see any problems here??? Please someone respond asap cuz the bidding is about to end in like 3 hours haha! thx
Old Feb 23, 2005 | 09:09 PM
Angel_408's Avatar
Default RE: Rims rp07's 18x7 Will they fit?
Oh and by the way here's a link with specs to the RIMs if anyone is intrested in looking at them http://www.enkei.com/PerfSpecPAGES/rpo7Specs.html
Old Feb 23, 2005 | 09:21 PM
1398spdr's Avatar
18x7? i think the 7 is just the width of the tire, but im not sure, if it is, then that means the tire width is smaller so you should be ok............... youll just need tires that fit...............oh, and def invest in a cam kit, less tire width means more pressure on the sidewalls, and you dont wanna be goin down the highway ridin on the wall of the tire.......... great lookin rims though.........
Old Feb 24, 2005 | 05:04 AM
Eclipsel3oy99's Avatar
yes the 18 is the rim size and the 7 would b width. and if 7.5 fit then you should b fine. the only thing that would make the differense is the offset. that would make the rim sit farther in or out. and if u dont know eclipse bolt pattern is 5 x 114.3. so as long as its the 5x114.3 then id say go for it. i doubt the offset would cause a prob especially cuz its only 7in wide. good luck with the rims they look hot.
ckmecha
Mar 10, 2013 12:52 AM
Rythmx2
May 14, 2008 03:01 PM
Fre$h_turk
Jul 29, 2007 04:56 PM
Fre$h_turk
Oct 17, 2006 07:49 PM
bradley D
Oct 3, 2006 05:49 AM
