ROUGH IDLE???????
Old Apr 13, 2007 | 11:14 PM
katinkid's Avatar
Default RE: ROUGH IDLE???????
bump!!! no one with knowledgeable info.
problem still not solved, im not sure what
Old Apr 14, 2007 | 10:53 AM
TheAdvocate's Avatar
ORIGINAL: katinkid
the top hole was already plugged up with a screw by someone else.
Thats not suppose to be plugged with a screw... Are you talking about the whole that is coming from the top of the valve cover pointing towards the intake?
Old Apr 14, 2007 | 12:28 PM
racerx55's Avatar
did you forget to plug in your airflow sensor?
Old Apr 14, 2007 | 04:18 PM
katinkid's Avatar
no i didnt forget to plug it in, but im starting to think it went bad!!!
but i cant tell if I have a CEL since the car wont stay on.
[blockquote]quote:
ORIGINAL: katinkid
[/blockquote] it was actually the top hole of the bsc restrictor. and i must have been driving like that for months since i bought the car.
I picked up an obd 2 code reader. so hopefully something will pop up.
all fuses are good!!!
Old Apr 14, 2007 | 05:02 PM
katinkid's Avatar
well since the ecu was reset, i dont have any codes. lol
only problem now is that i cant start my car for the ecu to read any codes. lol
my battery isn't strong inough to start the car. just for all acc.
Old Apr 14, 2007 | 06:50 PM
katinkid's Avatar
and code reader says.
camshaft positioning sensor - bank 1 circuit malfunction
so is it a bad camshaft sensor, or can something else cause that???
Old Apr 14, 2007 | 10:12 PM
racerx55's Avatar
check the connection there, ive had mine look like it was plugged in but it wasnt pushed on all the way and it barely makes a connection
Old Apr 15, 2007 | 12:34 AM
I Drive Naked's Avatar
ORIGINAL: TheAdvocate
ORIGINAL: katinkid
If its a 420A, I have the same thing.
A screw in a threaded hole in the valve cover.
But its bot a full hole, and theres a bracket between the screw and the valve cover.
It holds that vacuum line in place.
Old Apr 15, 2007 | 01:01 AM
a bad camshaft postion sensor will definetly cause the car to not start
Old Apr 15, 2007 | 01:11 AM
katinkid's Avatar
beautifull well thats my problem then. now i just need to remove the cam sprocket to get to it.
any ideas before i screw up my timing???
