runing problem idls fin mis at 3000 and 5500
i have a 95 eagle talon esi and it back fires alot when accl. to 3500 rps and 5500 rps the timing belt is new and put on correct. ive replaced the cam sen., crank sen. o2 sens. coil pack with a msd. 10.5 wires njk v-pow plugs any body have any ideas i think it the comp. but with the cam sens. unpluged i loss power form 4000 rpms and up but it dont back fire. i just add a cold air and exaust but it didnt do nothing differnt gaind little but still misses and back fires with the cam sens pluged in please help. any ideas
RE: runing problem idls fin mis at 3000 and 5500
ORIGINAL: XFadeLD
Check Your distributor, something might be preventing it from firing at higher rpms.
Did you check your base timing w/ a timing light? Just double check everything you replaced and make sure everything is plugged in and you dont have any missing vacuum hoses.
Is therea cel?
k yea i will try cause it started all when the timing belt went yess i was 1 of the .1 % that didnt smash the valves into the piston after it was the exaust cam that jumped but if it was fuel wouldt it do it when the cam sen. was unpluged to cause tats the only way i can even drive it it can give u wipwash
