runing problem idls fin mis at 3000 and 5500
Old Nov 30, 2007 | 01:32 AM
95talonesi's Avatar
Default runing problem idls fin mis at 3000 and 5500
i have a 95 eagle talon esi and it back fires alot when accl. to 3500 rps and 5500 rps the timing belt is new and put on correct. ive replaced the cam sen., crank sen. o2 sens. coil pack with a msd. 10.5 wires njk v-pow plugs any body have any ideas i think it the comp. but with the cam sens. unpluged i loss power form 4000 rpms and up but it dont back fire. i just add a cold air and exaust but it didnt do nothing differnt gaind little but still misses and back fires with the cam sens pluged in please help. any ideas
Old Nov 30, 2007 | 06:52 AM
Default RE: runing problem idls fin mis at 3000 and 5500
moved to 2g section so you can get more responses
Old Nov 30, 2007 | 11:02 AM
XFadeLD's Avatar
Check Your distributor, something might be preventing it from firing at higher rpms.
Old Nov 30, 2007 | 04:43 PM
TheAdvocate's Avatar
Are you sure you dont have it timed 180 deg out? Sounds like it is out of time/or 180 out..
Old Nov 30, 2007 | 06:38 PM
dsm1990gsx's Avatar
ORIGINAL: XFadeLD
There isn't a dist on 420a.
Did you check your base timing w/ a timing light? Just double check everything you replaced and make sure everything is plugged in and you dont have any missing vacuum hoses.
Is therea cel?
Old Nov 30, 2007 | 06:44 PM
I missed the fact that it was an esi Glad you pointed that out
Old Nov 30, 2007 | 08:11 PM
XFadeLD's Avatar
ORIGINAL: TheAdvocate
lol I did the same thing.
Old Dec 1, 2007 | 07:47 PM
dsm1990gsx's Avatar
You should also check your fuel pressure when it starts to missfire, it could be a fuel issue.
Old Dec 4, 2007 | 11:39 AM
95talonesi's Avatar
k yea i will try cause it started all when the timing belt went yess i was 1 of the .1 % that didnt smash the valves into the piston after it was the exaust cam that jumped but if it was fuel wouldt it do it when the cam sen. was unpluged to cause tats the only way i can even drive it it can give u wipwash
Old Dec 4, 2007 | 11:41 AM
So, you fixed the problem or no?
