Scared Of Crankwalk
Old Jan 17, 2008 | 11:01 PM
dorian7's Avatar
Default Scared Of Crankwalk
Is it just me or are other people scared of crankwalk? Does anyone actually know of the aprox % of DSMs that it happens to?
Old Jan 17, 2008 | 11:15 PM
estraw's Avatar
Default RE: Scared Of Crankwalk
prolly between 5-10% of people that arent nice to their cars. its not really too common of a problem
Old Jan 18, 2008 | 06:39 AM
So far from being on here i think ive only heard of about 5 or 6 on these forums. My old talon was starting to show signs of it so i sold it. And one kid around me had it happen to him. But its all about maintenance
Old Jan 18, 2008 | 09:43 AM
atown420's Avatar
i wouldnt be scared man. and if it does happen then bam you just throw in a 6bolt. not quite that easy. i am on the 4th engine in my car thanks to the last owners and none of the others had cwalk just mistreated and overboosted. but i wouldnt worry.
Old Jan 18, 2008 | 09:45 AM
dorian7's Avatar
What are the early signs?
Old Jan 18, 2008 | 10:09 AM
atown420's Avatar
-weird startup noise from timing belt area, its a screeching noise
-ticking noise coming from valve cover
-hydraulic fluid completely gone, resulting in my clutch pedal stuck to the floor
there might be more but those are the signs i have heard about
Old Jan 18, 2008 | 10:24 AM
ORIGINAL: atown420
Wow...not even close
-The screeching noise is a belt
-the ticking noise would be lifter tick
-it does not cause loss of hydraulic fluid
I think you have been mislead my friend. Here is the usual signs
-Clutch sticking to the floor (NO loss of fluid) it just sticks sometimes. And not from the carpet making it stick either, haha
-Low oil pressure at idle. Sometimes the oil light will flicker or come on (this is the problem i was starting to see
-main bearing slowely going out of spec (you would have to measure this one)
-Loud knocking from the bottom of the engine (usually is the last thing you hear before you car no longer runs
Old Jan 18, 2008 | 10:29 AM
there isnt anything wrong with walking a crank anyway....see
Old Jan 27, 2008 | 12:11 PM
50ul }{4ck3r's Avatar
ORIGINAL: TheEngineer
I f-ing Love it Engineer
Old Jan 27, 2008 | 12:28 PM
jlh077464's Avatar
Dont worry about it.....dont even think about it.....
