slight problem,help
slight problem,help
well here the problem my car runs perfectly when im going slow or even accelerating slowly,but when i realy punch it my car has a slight jumpat high rpms,very small.when i was shifting fast from 1st to 2nd,my car had a slight jump in 2nd gear.could it be my spark plugs,i have the ngk iridium ix if that helps,they are moderatly new.maybe 4 or 5 months.stock ignition wires
RE: slight problem,help
what do you mean by jump. Like the rpms go up alittle faster than they should and your not really going. Almost like you just rev'd it for a sec. because if thats the case it could be the clutch
are you loosing any performance when this happens? is it like a hesitation/stumble in the engine before it gets on it? you have a very vague description of your problem, with some more detail we can disect the problem better
its nice to see a thread that confirms it as well. Because i had heard of people having problems with them but now its good to see where it was definetly the problem. Thanks for letting us know
ussprinceton2004
09-04-2006 02:01 AM
