Sluggish at low rpm
Old Dec 11, 2005 | 06:41 AM
mtalma's Avatar
Default Sluggish at low rpm
Hey, my car is performing really poorly at low rpm. I need to have the injectors cleaned but i don't think thats totally the problem. I have also been told that the timing belt needs to be replaced at the fuel pump needs to change. Could these things be causing the poor performance?
Old Dec 11, 2005 | 10:19 AM
get435's Avatar
Default RE: Sluggish at low rpm
model? miles? mods? Maintanace?
Old Dec 11, 2005 | 04:37 PM
mtalma's Avatar
Its a 98 eclipse gst spyder. No mods (as yet) pretty much stock. Its at 98,000 miles and was lady driven until me. I just bought the car a couple weeks ago and I had a general tune up done - injectors changed, oil change etc. Any thoughts?
Old Dec 11, 2005 | 04:52 PM
domestickilla's Avatar
ok ill throw out my .02 people can correct me n add as they feel needed, i have a 97 GS-T if i was you i would replace yur plugs n check your wires, i firmly stand behind NGK i would suggest you getting some BPR8's, when i bought my GS-T it had 86k on it n the previous owner put Bosch platnum 4s in it n it cooked my wires so check your wires also.The timeing belt should be changed every 60k miles or so. i myself dont trust the corner lot shop n had mine chaged at the dealership to make sure it was done right. another thing to change would be the fuel filter cheap (30 bucks) n easy to install its just kinda a bitch haven to pull the battery n everything to get to it but youll see its not hard. oh and unless its been done recently id have your other belts changed as well kinda cheap insurance. i would start there n start elimanting options.once you get it running dont forget to do your free mods[8D] it being a drop top youll need the extra to move the more weight
g1bishi
Oct 27, 2006 02:09 PM
mightymo
Jun 15, 2006 01:38 AM
jeffery0266
Jan 26, 2006 06:18 PM
jeffery0266
Jan 26, 2006 10:07 AM
dsagal79
May 28, 2005 06:17 PM
