Something Weird
Old Dec 8, 2004 | 10:07 AM
Dans Talon's Avatar
Default Something Weird
My driveway dips downward and so I park my Talon 1.8l on a slant.
Whenever I park it slanted frontward-downward it starts up smoothly-no bearing noise.
but...
whenever I park the car with the back slanting downward at start up -the engine makes rod-bearing-ticking noise for about 6 seconds until the oil pressure builds up.
The oil filter is mounted on the side of the engine facing the front bumper and so I figure that when I park the car on a downward slant facing forward the oil is all leaning forward into the oil-pick-up-tube-oil-pump-oil-filter assembly and so this helps the car to lubricate almost immediately without some few second delay.
Dt
Old Dec 8, 2004 | 02:47 PM
1398spdr's Avatar
Default RE: Something Weird
interesting........ i park on a slight slant also, maybe i should try parking downslant more often.........
Old Dec 8, 2004 | 03:31 PM
SpyderGS's Avatar
That's a 4g9- series engine right? That is weird, but not unbelievable.
Old Dec 11, 2004 | 12:38 AM
vertstanggt's Avatar
Sounds pretty logical to me, the oil's probably stuck on one side of the pan when it makes noise and isn't picking up as much as when you're facing the other way.
Old Dec 13, 2004 | 07:46 PM
SpyderGS's Avatar
Well, usually the oil pan would be filled with enough oil so that it won't ever have a dry start-up...atleast on the 4g6x engines....i think it's pretty neat.
Old Dec 14, 2004 | 08:24 PM
Don't know where the level sits full in these, I was just going on logic. Maybe the oil pump isn't pulling as strong as it should.
Old Dec 19, 2004 | 05:51 AM
midnght's Avatar
ORIGINAL: vertstanggt
This is a good possibility. Maybe a diagnostic is needed. Or you just have the typical lifter tick most people driving these cars have. Be it 4G63 or 4G93.
EMonz57
Feb 4, 2008 02:44 PM
betomn
Aug 9, 2006 03:05 AM
TEAMNEMESIS
Jul 7, 2005 02:39 PM
jabawaki
Jun 22, 2004 10:16 AM
91eclipse
Mar 11, 2004 04:38 PM
