speedmoter showing too fast? Help!
Old Dec 17, 2006 | 01:41 AM
locoal619's Avatar
Default speedmoter showing too fast? Help!
got a 96 eclipse gs, and when I'm driving at 55 mph, speedometer showing 110mph, need some advice from ya guys........Was thinking that it may be a loose speedometer cable or maybe something with a speed sensor, any suggestions? thanks
btw, has 17in aftermarket rims
Old Dec 17, 2006 | 06:18 AM
5Tizzle's Avatar
Default RE: speedmoter showing too fast? Help!
youre probably actually doing about 110
jk....idk
Old Dec 17, 2006 | 10:32 AM
silvercoupe97's Avatar
Welcome to MF locoal619.
I would definitely check your speedo sensor. There are many types and I'm not sure if you have a mechanical or electrical but either way I would check that. Do you have aftermarket rims? When did this start? What new mod did you do (trying to find any type of correlation)
Old Dec 18, 2006 | 12:14 PM
locoal619's Avatar
ORIGINAL: silvercoupe97
I do have aftermarket rims, the car had this problem when I bought it, previous owner thinks it started shortly after the engine was rebuilt, he thought that it may be some gear behind the dash gauges.just wondering if anyone has this problem....................................
Old Dec 28, 2006 | 11:40 PM
locoal619's Avatar
any other suggestions?
Old Dec 28, 2006 | 11:54 PM
paintballproam's Avatar
does the speedo just shoot up all of a sudden? like if you did a 0-60 would it rocket up to 110?
Old Dec 29, 2006 | 04:35 AM
Simss's Avatar
use it to your advantage of intemidation, tell all your friends that your car does 80 in first gear and explain that your car is so fast that when you go these speeds, the car actually goes faster than is allowed in the physical world that we live in so therefor it actually looks and feels like you are going slower. then you must start talking about quantum physics and the theory of relativity...
interestingly enough though my friends dad's truck(gmc) does this but goes back to normal after he beats it a few times.
Old Dec 29, 2006 | 04:57 AM
5Tizzle's Avatar
Do you have 8 inch wheels?
Old Dec 29, 2006 | 05:31 AM
ORIGINAL: Jeffisdecentttttt
Lmao....
What size are your rims, it does sound like your total wheel diameter is too small, that's why I asked if you had aftermarket rims. The previous owner could have wanted too small of a profile tire and unknowingly affected the speedo.
Old Dec 29, 2006 | 05:43 AM
5Tizzle's Avatar
Lmao....
Theres no way he actually has small enough wheels to throw it off that far. He actually would have to have 8 inch wheels to double the speed.
Sounds like a sensor malfunction.
