spray a 420a
Old Nov 26, 2005 | 08:48 PM
95EclipGS's Avatar
Default spray a 420a
how much spray can a 420a stock engine take on a 95 eclipse? the engine block is iron so it should be fine, and i hear that most any car can handle a 50 shot. anyone know if 75-100 is pushing it, or what the max is for a 2nd gen eclipse?
Old Nov 26, 2005 | 10:17 PM
TheAdvocate's Avatar
Default RE: spray a 420a
25 would be safe... 50 your taking a chance... should be able to handle it tho... But don't even try the 75 or 100... Not if you like your motor...
Old Nov 27, 2005 | 12:03 AM
slow420a's Avatar
My friend was shooting 80 in a 70k 420a, absloutly no problems. No problems. Personally I wouldent go over 100, track 125 once or twice just to check it out but dont go over 100 daily.
Old Nov 27, 2005 | 11:51 AM
anything more then 50, your gonna be floating your valves... Never a good thing to keep doing to your car...
Old Nov 27, 2005 | 03:14 PM
eclipsed4u's Avatar
it will also depend on IF he knows how to use it. if he is going to be careless with it and act like his on 2F2F, then a 50 shot will be enough that he won't blow the engine. if he is responsible when using it, then a 75 shot would be good.
Old Nov 27, 2005 | 04:31 PM
95EclipGS's Avatar
wet or dry?
Old Nov 27, 2005 | 11:21 PM
slow420a's Avatar
wet a bit harder to set up... safe
dry very easy to setup... not to safe
Old Nov 27, 2005 | 11:58 PM
Patrick's Avatar
Administrator
i ran a 420a with a Zex 55 wet shot last summer...it ran 15.0s with 130k, and a new clutch/diff, but completely stock engine.
lumbee4live
Aug 14, 2008 07:09 PM
maharajah
Feb 23, 2007 04:09 PM
cchrisj01
Jan 27, 2007 04:28 AM
EdZorX
May 23, 2006 12:36 PM
x_upjohnson
Dec 1, 2004 07:31 PM
