Sputtering
Old Sep 27, 2006 | 09:30 AM
Default RE: Sputtering
it could be the sensor but i think the car would throw a check engine light if it was.
Old Sep 27, 2006 | 09:54 AM
RCJr9186's Avatar
i had the same problem in my car.... i changed the plugs, nothing, changed the wires and plugs, nothing. then i changed the coil pack, come to find out there was corrosion on one of the ends causing it not to send the full spark to the wire > plug > cylinder. changed it out and i've been good ever since.
Old Sep 27, 2006 | 12:20 PM
burnmyeyes's Avatar
When I was pulling it into my mechanic's parking lot it threw a code finally, so I should know what the problem is shortly thank god.
Old Sep 27, 2006 | 02:10 PM
maybe it is the sensor then
Old Sep 27, 2006 | 03:36 PM
burnmyeyes's Avatar
maybe. A few months ago it was running bad, blowing alot of smoke, I had no idea what the hell was wrong and neither did the mitsubishi dealer. I thought the car was going to die, then it threw a code and I needed an O2 sensor, and its been okay since now.
I do think it is funny how I hope and pray that the CEL will come on so I can know whats wrong with it.
Old Sep 27, 2006 | 10:12 PM
Sanguinius's Avatar
I actually had a plug wire go bad and break the insulation at the boot. It was the #3 wire and when that happened it started sending spark to the #4 cylinder when 3 was supposed to be getting it. Talk about an interesting troubleshooting session for me. If I hadn't started hearing the spark jumping and arcing I'd probably never even thought of it being the wires (They had less than 1K miles on them).
Old Sep 28, 2006 | 10:47 AM
must have been pretty ****ty wires
Old Oct 2, 2006 | 10:57 AM
burnmyeyes's Avatar
Well it wasnt the plugs or wires. It turns out it was 2 wires on the MAF were touching causing it to run terribly. Another problem solved. Thanks guys.
Old Oct 2, 2006 | 12:08 PM
wow thats a new one on me, haha
Old Oct 2, 2006 | 01:07 PM
Dookitchen's Avatar
what is MAF?
