Spyder tranny question...
Old Aug 23, 2010 | 08:59 AM
claytonkobe's Avatar
Default Spyder tranny question...
Will any other tranny fit in the 98 spyder? im having trouble finding a auto tranny for my 98 2.4L. Also, is changing the shift syncros hard to do. I know you have to split the case but wht does it entail? Right now i have 1st gear until it warms, then none. NO REVERSE
Old Aug 23, 2010 | 09:45 AM
you can only get from 97-99 auto transmission from an eclipse 2.4L. Check out this website for used transmissions http://car-part.com/ i found plenty in my area
Old Aug 31, 2010 | 12:34 PM
Thanks man! Got a tranny. got it in. NOW THE ENGINE WONT TURN OVER
HELP!!!!!!!!!!
Car ran fine before tranny was out. i turned it to align the spindle with the inside dowls in the torque converter. everything went in fine. all is hooked up. in neutral, car rolls fine. Starter is fine. When you turn the key, is engages but doesnt turn over. Sounds SIMILAR to when ur starter is bad but this on is not. There is the distinctive shift of the motor when engaging, just will not crank. Yes, tried with jump box, another car and a different battery. still, just cranks like frozen. both were tested,and neither were. so, whats next? ........
rocket1173
Dec 16, 2009 04:50 PM
badass91hatch
Jan 16, 2006 05:09 AM
kandy eclipse
Dec 12, 2005 08:01 PM
sguerrero
Apr 13, 2005 01:19 AM
Scot
Apr 6, 2005 04:21 AM
