Squeeky BELT
Old Aug 7, 2007 | 09:18 AM
tidus10's Avatar
Default Squeeky BELT
i started up my car today and it started squeeling like a piggy, like bad...i reved it up and still squeeked louder...figured it would go away like it normally does...NOPE it went on for 10minutes down the road and all i smelt was burnt rubber.....
what could this be? how much is a belt normally?
Old Aug 7, 2007 | 10:22 AM
Dusty Eclipse's Avatar
Default RE: Squeeky BELT
Belts are cheap... but are you sure thats the only problem?
Old Aug 7, 2007 | 10:24 AM
RCJr9186's Avatar
if you smelt burning rubber you may have a seized up pulley somewhere... is your ac working? power steering? is the temp of ur engine normal? could just be a bad belt also. only about 15 bucks and 20 minute change out
Old Aug 7, 2007 | 10:30 AM
tidus10's Avatar
my AC blows cold, but not as cold as it was befor? power steering is still going strong...i say its a belt due to the fact that when my motor revs up the sound gets greater
Old Aug 7, 2007 | 10:37 AM
RCJr9186's Avatar
that's common, sounds like an AC belt. try to tighten it for most of the time when they squeel they are just a lil loose. if it is plenty tight than i'd replace it. i'd rather pay 15 bucks and 30 mins of my life than listen and be embarrased at every stop light listening to wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old Aug 7, 2007 | 10:41 AM
tidus10's Avatar
its more like SQUEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEEE (stop) QUEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEEEEEEEEEEEEEEEEEEEE (stop) weep (stop) QUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARK then i'm driving again and it stops
Old Aug 7, 2007 | 10:45 AM
Im still leaning toward siezed up pulley...
Old Aug 7, 2007 | 12:08 PM
RCJr9186's Avatar
if everything is working as it should. it's not a seized pulley.
Old Aug 7, 2007 | 12:10 PM
He was saying his AC doesnt blow cold anymore.
Old Aug 7, 2007 | 12:25 PM
RCJr9186's Avatar
freeon recharging most likely. change the belt, it will fix the squeel. case closed. if not you have a worse problem w/ a pulley.
marx88
Jun 30, 2011 03:54 PM
burto1
Jan 5, 2010 11:32 AM
agallardo
Oct 29, 2006 11:33 AM
EMonz57
Jul 16, 2006 07:43 PM
dadandcoach
Dec 1, 2003 08:53 PM
