Squeeling belt?
Old Feb 11, 2005 | 01:21 AM
DaShot19's Avatar
Default Squeeling belt?
Well i think its either fan belt or serpentine belt, and its squeeling. Got a 99 eclipse spyder, gs, and well, i owned a galant before this that had same problem. how can i fix this without takin it to shop and make sure it will not squeel anymore cause already had it fixed once.
Old Feb 11, 2005 | 08:44 AM
redeclipse's Avatar
Default RE: Squeeling belt?
Shoot it with some belt dressing before you replace it, could just be dried out a little.
Old Feb 11, 2005 | 10:11 AM
get435's Avatar
Did you dirve through a puddle? i know if i hit a watter puddle that is large my belts will squeel just a little than it goes away once the water is gone. just a question is this normal? and it is only when i try to accerate that it squeels.
Old Feb 13, 2005 | 11:55 PM
customizedrides's Avatar
I personally don't like the belt dressings only because I've found they it sits in the threads of the belts and causes more slipping. I would say look at the belts and see the conditions of them. If they look worn, replace them and see if that solves it. Another thing it could be aswell is a bearing inside the engine. I had a Maxima with a timing chain, and there were two bearings it rode on that would sqeel primarily when I accelerated or when it was really hot out. It could be somehting alond those lines. Good luck!
Old Feb 14, 2005 | 10:11 AM
t3t4turbo's Avatar
lol, you dont have a fan belt. We have electric fans on all cars now. But it could be your Power steering or waterpump/alternator belt.
Try tighting them up a bit.
Old Feb 14, 2005 | 04:01 PM
MORRISSEY's Avatar
I had this problem before, it went away after i replaced the pulley and serpentine belt.
Old Feb 14, 2005 | 10:06 PM
RiseoftheEclipse's Avatar
ya i had that problem to...I just changed the belts and it worked out..(or could be if something is hitting the plastic cover next to the belts)
Old Feb 19, 2005 | 08:16 PM
GQ_Money's Avatar
HAHA, funny, I bought mine yesterday (97 Spyder) and its belt squeels. i hope it's just the belt that needs replaced [&:]. The sound goes away when I press the gas. BTW, when is it recommened to change the timing belt?
Old Feb 20, 2005 | 09:42 PM
I believe it's every 75 thousand miles to be safe!
Old Feb 21, 2005 | 01:18 AM
99clipsgst's Avatar
I heard it was every 60,000. if you dont keep an eye one it it can kill your interferance motor. Me personally when ever i buy a used car that is the first thing I change.
