stalling out!
Old Dec 3, 2006 | 06:03 PM
bud660r's Avatar
Default stalling out!
well my car will start up fine but when i put it in to gear it will start to move and then it will just quit!"my clutch is on it's way out i mean it's bad couldthis
cause it to stall and quit" after it stalls out it still starts up fine. also it will not stall if i shift be for 3500rpm's
any info about this would be awsome it's a 95 GS eclips
Old Dec 3, 2006 | 09:04 PM
93eclipsegsx's Avatar
Default RE: stalling out!
well if its stalling, just give it a little more gas.
Old Dec 3, 2006 | 10:10 PM
bud660r's Avatar
i shouldent say stalling sorry my fault. more like just dies, try to give it gas i dont even get a response, but the motor just stops running outright! like i shut it off, but when i turn the key to the off posishion and try and turn it on is fires right up.
sorry i am a bad speller, and i am probably being realy unclear right now!
Old Dec 4, 2006 | 12:37 AM
estraw's Avatar
you said when you put it into gear, it will start to move. do you mean it is moving while you have the clutch pedal in? if so your slave cylinder is probably shot.
Old Dec 4, 2006 | 08:59 PM
bud660r's Avatar
whell i can ride the clutch a little till it gets up to speed! then from there if i shift be fore 3500rpm's it will not die! but if i go past 3500 it will just die!
ncmountie
Nov 7, 2019 11:54 AM
McNeil
Jun 5, 2009 09:35 AM
shylae21
Nov 8, 2007 04:59 PM
PooT_Nation
Mar 6, 2006 05:39 PM
1998blackgst 240
May 9, 2005 07:50 PM
