stalling while running
Old May 3, 2005 | 09:46 PM
1998blackgst 240's Avatar
Default stalling while running
everytime i press the clutch when im moving the engines rpms drop to about 200 then come back up, but when i accelerate hard then get on the clutch the engine just stalls in the middle of me driving, is it a problem with the idler or what, i almost went through an intersection cuz i was trying to make a right turn and the car turned off when i got on the clutch what is the problem?????!!!
Old May 4, 2005 | 03:45 PM
DSMTalonAWD51's Avatar
Default RE: stalling while running
check first: for vacuum leaks 90% chance there is a loose hose
2nd: adjust your idle
Old May 6, 2005 | 02:34 PM
patsevo8's Avatar
I am sure you've heard of walking crank? This is one of the symptoms of it. When you're making right/left turns and/or when you have an aftermarket clutch.
Do you have aftermarket clutch?
Old May 6, 2005 | 07:09 PM
thats a small symptom of crankwalk and an almost definite symptom of a vacuum leak. However, he does not have crankwalk because you would have other symptoms first. How do I know? I have had it. And I have read everything there is to know about it.
Your car does not stall after left/right turns, the clutch sticks to the floor after a left turn.
You would also hear a loud clicking when you press the clutch in while idling.
the stalling only comes after these symptoms and i would not even worry about cw unless you notice the clutch sticking to the floor, thats the #1 sign.
Old May 6, 2005 | 08:56 PM
o yeah i know its not crank walk, i checked some hoses a few of them seem a little loose and its been better so i guess it was just that, i might have a leak in one though i gotta check more. thanks alot
Old May 8, 2005 | 05:02 PM
patsevo8's Avatar
Look cowboy, not all symptoms of walking crank are the same. I was doing a 1/4 mile run when I had it.
Just because he's not hearing clickity clank, doesn't mean he doesn't have it.
Old May 9, 2005 | 02:13 PM
get435's Avatar
well i have to say crank walk is a problem you will check last not first. because 99% of the time it is somthing stupid like vac lines.
Old May 9, 2005 | 03:30 PM
patsevo8's Avatar
I realize that the chances are that it is not walking crank. But the fact of the matter is, their is still that chance. That's all I am saying.
Old May 9, 2005 | 07:50 PM
ORIGINAL: patsevo8
LOL, you were doing a quarter mile run when you had it?? You dont just get it during a race, your crank bearings slowly wear out over time, the symptoms get worse, and eventually your car stops running entirely becuase it wont go into gear. And yes, all symptoms are the same, because the exact same thing is happening....
puwit321
Nov 29, 2022 11:24 PM
kainrath
Aug 21, 2006 06:11 PM
2001gt3.0
Jul 18, 2005 05:10 PM
bdunn
Dec 1, 2004 03:38 PM
T76 turbo
Sep 9, 2004 03:12 AM
