Starting Problems
Old Feb 4, 2008 | 08:54 PM
eclipserunner269's Avatar
Default Starting Problems
Hey all whats up? i got a 95 eclipse gs with a starting problem. it's getting spark and turns over but wont fire up and run at all, anyone know what the problem may be?
Old Feb 4, 2008 | 09:33 PM
estraw's Avatar
Default RE: Starting Problems
is it getting fuel?
Old Feb 4, 2008 | 09:54 PM
How do you know its getting spark.
Well, it could be a few things. 3 things are needed for combustion.
Oxygen, Fuel, Ignition... all in the right ratio.
Find out what it is your missin'!
Old Feb 4, 2008 | 10:10 PM
estraw's Avatar
ORIGINAL: Sebba
Well, it could be a few things. 4 things are needed for combustion.
Oxygen, Fuel, Ignition, Compression... all in the right ratio.
if you have fuel, do a compression test. they solve everything
Old Feb 5, 2008 | 07:52 AM
if your car doesnt start because of compression you would have some serious problems . Compression is part of the proccess but i dont think it should necessarily be part of that list only because its by the mechanical parts. Its not something that i dont think would give this issue
Old Feb 5, 2008 | 08:42 AM
estraw's Avatar
how could it NOT cause a no-start? just because his compression is off doesnt necesarilly mean something serious happened? his timing could just be off a little bit and that could very well cause it not to start
Old Feb 5, 2008 | 09:36 AM
Timing being off yes that will cause a no start. But in that case wouldnt it be easier to just check the timing marks on the cams for that?
Old Feb 5, 2008 | 11:22 AM
I was talking chemically.... lol
Old Mar 17, 2008 | 05:20 AM
yea i changed the plugs and they smelled strong of fuel
Old Mar 17, 2008 | 05:22 AM
well its gettin air and fuel, and check the plugs for spark. but it looked weak the spark looked weak
