Starting Problems
Old Mar 29, 2008 | 01:09 PM
Scubba.steve's Avatar
Default Starting Problems
I have the 420a in my talon and cold start fires right up. Once the car has ran for an hour and then shutting it off it fires right back up. But if i let it set for more than 15mins Its very hard to start. Takes about 10seconds of cranking. whats the deal?
Old Mar 29, 2008 | 03:37 PM
PappiDread6's Avatar
Default RE: Starting Problems
From what little your sayin I would say test your battery and alternator, alsoafter you turned over the motor a couple times pull a spark plug and see if you getting fuel. Check for any stored codes, and check for blown fuses. How are you gettin the car to run again?
Old Mar 29, 2008 | 06:51 PM
Battery and altenator are fine. Car starts just fine when cold. Just if i drive it for more than 30 mins and shut it off Its hard to start back up. take a couple of cranks. No codes coming up on obd2 or blown fuses....
Old Mar 29, 2008 | 11:04 PM
Spark plugs or spark plug wires.
Old Mar 30, 2008 | 06:49 AM
Are brand new. and if that were the case car wouldnt start fine while cold and haveproblems once warmed up
Old Mar 30, 2008 | 09:47 AM
98gstspy's Avatar
to me it sounds kinda like a solonoid on the starter, but that is me. similar problem but it did that for about a week, then would only start when everything was cold. so it sucked when i had to leave my car in a parking lot over nite look into it pull the starter and have it tested dosnt hurt anyways
Old Mar 30, 2008 | 09:59 AM
If the starter was bad it wouldnt crankover would it? the car cranks over just fine.. Just has a hard time starting once its warm
Old Mar 30, 2008 | 12:01 PM
Im betting the coil is arcing when warm.
Old Mar 30, 2008 | 06:59 PM
Coil Pack? Dunno it could be. My friend just gave me a new throttle body.... somehow he seems to think thats the problem. I dont but who knows. i will install that and see
Old Mar 30, 2008 | 07:03 PM
Uuuh... yeah lol
