still fuel cuting
Old Jul 22, 2007 | 05:02 PM
anko_kun's Avatar
Default still fuel cuting
ok i im stumped now its time for yalls thoughts on it 14psi and fuel cuting with a stock fuel pump that has a rewire its in first and second gear when im geting in to it it sucks please help ..... thanks
Old Jul 22, 2007 | 05:56 PM
tjbiker031's Avatar
Default RE: still fuel cuting
whats your mods, upgraded turbo? injectors?
Old Jul 22, 2007 | 06:00 PM
anko_kun's Avatar
1.Extreme PSI intake
2.Megan racing catback
3.luk pro gold clutch
4.strut bar
5.greddy turbo timer, boost gauge, a/f
6.CCM smic pipe
7. 1gen bov
8.voodoo mbc 14 psi
9.ngk bpr6es plugs
10. lok tech 3 gauge pillar tan
11. e-bay short shifter12. fuel pump rewire 10g
Old Jul 22, 2007 | 06:34 PM
tjbiker031's Avatar
did the pump cut out b4 the rewire? it might evenbe clogged fuel filter.
Old Jul 22, 2007 | 06:40 PM
anko_kun's Avatar
ya it cut out
Old Jul 22, 2007 | 06:53 PM
tjbiker031's Avatar
then you might want to buy a new pump, sounds like your pump is going out.....i could be wrong, but thats what it sounds like to me.
Old Jul 22, 2007 | 07:06 PM
anko_kun's Avatar
could be i dont think so though ill try the filter first and get some more intel
Old Jul 22, 2007 | 08:58 PM
silvercoupe97's Avatar
Do you have the honeycombs removed?
Do a boost leak check first. The ECU is probably seeing that you're reaching it's max airflow and is trying to save your motor from hurting itself.
There's no reason that you should be hitting fuel cut on a stock system unless you've got an air leak btw.
Old Jul 22, 2007 | 09:32 PM
anko_kun's Avatar
honeycombs?its runing better now i found a smallboost leak in the bov gasket
Old Jul 22, 2007 | 10:34 PM
I take it you didn't remove them and didn't happen to look into the MAF itself, lol.
That boost leak isn't that small to throw off the ECU to make it cut. Fix it and try again, there could be more. Don't think that just because you found one, that there couldn't be another That's a common, DSM'ers misjudgement.
