Still high idle issue
Old 03-23-2008 | 04:55 PM
tjbiker031's Avatar
Default RE: Still high idle issue
its throwing the code because somewhere its letting in more air causing the ISC to "malfunction" and the computer throwing the code. just first like silver said do a boost leak test. make a tester or buy one...i think boostpro.net makes one with a pressure gauge built-in so you don't gotta run inside to car to look at your boost gauge so you dont over pressurize the system.
Old 03-23-2008 | 09:27 PM
oh_what_up's Avatar
I would say its the fiav. They make a block off plate which lets you keep your ISC motor. As the engine warms up its supposed to close, not letting as much air bypass the throttle plate (its a simple thermostat). Yours seems stuck open, letting air continue to bypass the throttle. You might want to check the throttle shaft seals as well. I had this same problem, but to fix it I went a little over board. I replaced the throttle body gaskets, the BISS screw and o-ring, the throttle shaft seals, and put in the FIAV block off plate. My idle is perfect now. however, without the FIAV, its a little choppy if its a cold morning. If its warm though its perfect
Old 03-23-2008 | 10:48 PM
OhioEclipse's Avatar
Thank you to everybody that replied, you have given me some stuff to do now all I need to do is go out and do it.
Old 03-24-2008 | 12:00 AM
tjbiker031's Avatar
lol have fun....it took me a month before by the time i researched the causes and how to fix it, but atleast you got a few things to do.
*remember, go from simple solutions (which are usually free) and then work your way up tothing that can cause you moneythat can be causing it.
yamahablaster8230
08-29-2006 10:28 AM
jdragon1974
08-01-2005 01:56 AM
dnau
04-24-2005 06:12 PM
1rippinGT
04-07-2004 07:09 PM
shmadiohead
02-23-2004 06:22 PM
