Stock BOV
I just bought a 97 GST and i dont have the money to buy an aftermarket BOV and i want to make the stock one atmospheric. what do i do besides take the hose thats conected to the BOV and intake? i know there is something i can do to make it so the engine will run smooth with it like that. your help is much appreciated.
Uhhhh...i dont think you can make it run as well without, as it can with. Aftermarket bov doesnt cost that much. Greddy type S bolts up the easiest, i believe.
BOV
The cheapest way to get quick power out of your car is to get a boost gauge, and a manual boost controller. you can gain something like 50 hp by running 15 psi(The max your stock fuel system can safely run at...Otherwise, there arent any ways to get out of spending money.
BOV
Your manual allows you to turn up your boost from either 8 or 12 (can't remember) to whatever you want (15 max as stated above on T-25). It just a simple twist of a ****. Looks like this:
Your stock BOV on that 2g is not very good. Leaks under higher boost. Venting that BOV is not a good idea. Your car will run horribly! Plus MOST of the time you need something like an AFC to vent so you can compensate. Get used to spending money because you can hardly do one upgrade without another and if you take the cheap route your car will live up to the DSM name. Good luck!
ORIGINAL: talon4show
Well you splice into two vacum lines, one of which comes off your BOV. I forget exactly but VFAQ it.
and the enitre MBC hook up with pictures has been talked about in the past I know I posted pics for it so if need just search and you find it somewhere in the eclipse section
