strut bars?
Which is a good strut bar? What makes a strut bar "bad?" What strut bars do you guys recommend?
RE: strut bars?
what makes a strut bar bad? if it is not one bar. if it is two or three bars bolted together, it will do absolutely nothing.
RE: strut bars?
I got the ebay specials on mine and they are good.
RE: strut bars?
So I can purchase a strut bar for $5 instead of a $100 strut bar and it would do the same thing? Or is there a difference?
RE: strut bars?
the only real difference is in the quality of the product (material). Such as how long they will last. But as far as handiling goes i would suspect that they give about the same.
RE: strut bars?
Thanks.
RE: strut bars?
um i had strut bar on my old subaru xt turbo probably never heard car but i didnt feel a diffrent with the ones sell in shop that just go across the engine then my and my bro welded another alluminum bar to firewall so it would be in tri-angular shape, then i felt a diffrence those other fruityones dont do much and are bearly notcible
only reasone i did that was cause it impossible to find part for that car |
RE: strut bars?
Just before I sold my 97 gs to a friend of mine I put one of those DC Sport carbon steel bars up front - $100 shipped on ebay, and rigged the rear up with an OBX strut bar and lower tie bar - $150 for both shipped. He has since put some rims on it and it does not budge around corners. I'll warn you that without some type of powered tool, that lower tie bar will probably piss you off more than anything. I had an impact wrench and it still took the better part of an hour to get the nuts off the bolts, get the bar positioned and put the nuts back on
