Sunroof problem
Old Oct 30, 2007 | 05:21 PM
sonicdrft's Avatar
Default Sunroof problem
my girlfriend just bought a 95 eclipse rs and the guy that she bought it off of says that the sunroof leaks...now i dont know how bad but i was just wondering if this is going to be an easy fix or hard or maybe a common thing...thanx great forum
Old Oct 30, 2007 | 05:52 PM
sk8dudety's Avatar
Default RE: Sunroof problem
maybe replace the seals?? i know my sunroof leaks and i just siliconed the glass down lol... but mine never worked anyway, so it didnt matter to me
Old Oct 30, 2007 | 08:34 PM
Nubiebubie_GSX's Avatar
I had a leak also but would only notice it after a long rain session. Unclogged the drain and that was it. Seals were crack also but no water leaked after i unclogged it.
Old Oct 30, 2007 | 09:41 PM
dsm1990gsx's Avatar
Drains are probably clogged.
Old Oct 31, 2007 | 07:21 AM
RCJr9186's Avatar
I think you may have a GS. i don't think that a sunroof was optional in an RS. ANYWAYS this is one of the most common problems w/ Mitsu's. The drain is clogged. get an air compressor and blow it down there or a metal hanger.
Old Oct 31, 2007 | 10:48 AM
sk8dudety's Avatar
yea my rs was an aftermarket one the guy put on before i had the car... it never worked from the time i got it
Old Nov 2, 2007 | 03:42 PM
sonicdrft's Avatar
hmm well come to find out the sunroof dont work either...u hit the button and u hear the motor running but no action...and well the hatch says that its an RS...?thanx
Old Nov 2, 2007 | 04:01 PM
darknigh7th's Avatar
my old next door neighbor had a sunroof on her RS, but i wasn't a electronic, does it have a windshield wiper in the back, because I think GS and up had the only electric things, I could be wrong though.
Old Nov 2, 2007 | 05:39 PM
You can manually crank it open or close can't you.. I was told you could, but never tried since mine works. I was told under the cover where the buttons for the roof are, there a alan key socket that u can use to turn which opens and close the sunroof. Dont know how true it is. Doesn't seem likely, but throwing it out there.
Old Nov 2, 2007 | 07:55 PM
if the motor is working then its probably the gears are off. See if you can try and get to it somehow.
