suspension squeeks
I have 1998 GS.
Suddenly something in the engine area started to squeek ( just like an old door) It happens when I accellerate/deaccelarate and turn. Squeek stops then I drive at steady speed. I tried to push the suspension vertically nothing happens. When I push car horizontally it starts to squeek. Any ideas? Thanks for help PS: I cannot localize it exactly but it is on the driver side on the engine bay area ( between the engine and the firewall) |
RE: suspension squeeks
okay when the suspension squeaks it can be good or bad usually good cause it means that its still stiff wich is a good thing. The noise could be many things like a heat sheild on your brakes or (dust Shield) could be your shocks or something if it really bothers you then you should go ahead and take it to a professional shop. Good Luck!
