suspension squeeks
Old Jun 16, 2004 | 06:14 PM
jacek's Avatar
Default suspension squeeks
I have 1998 GS.
Suddenly something in the engine area started to squeek ( just like an old door)
It happens when I accellerate/deaccelarate and turn. Squeek stops then I drive at steady speed. I tried to push the suspension vertically nothing happens. When I push car horizontally it starts to squeek. Any ideas?
Thanks for help
PS: I cannot localize it exactly but it is on the driver side on the engine bay area ( between the engine and the firewall)
Old Jun 16, 2004 | 07:02 PM
reallyaLS1chick's Avatar
Default RE: suspension squeeks
okay when the suspension squeaks it can be good or bad usually good cause it means that its still stiff wich is a good thing. The noise could be many things like a heat sheild on your brakes or (dust Shield) could be your shocks or something if it really bothers you then you should go ahead and take it to a professional shop. Good Luck!
milo145
Feb 1, 2010 08:25 AM
miche77e
Oct 31, 2005 12:16 AM
Galantz01
Feb 19, 2005 04:43 AM
mrgordijev
Feb 5, 2005 05:58 AM
ivanejackson
Oct 11, 2004 12:07 PM
