thanks
Old Jan 20, 2009 | 11:36 PM
jsawyer's Avatar
Default thanks
well thanks to all that helped me out figuring out my car i finally got her going turned out that the o2 circut in my ecu went out but thanks to all that helped
Old Jan 21, 2009 | 06:27 AM
Default RE: thanks
wow the actual ECU was bad? and in a 2g thats not to common
Old Jan 21, 2009 | 05:33 PM
jsawyer's Avatar
Default RE: thanks
well when i blew the moter the exaust manifold cought on fire and melted the o2 wires together and that shorted the ecu out
Old Jan 21, 2009 | 06:26 PM
Default RE: thanks
That makes perfect sense!
Glad you worked it out.
Old Jan 22, 2009 | 06:52 AM
Default RE: thanks
wow, running a bit lean i take it to get that hot.
Old Jan 22, 2009 | 07:25 PM
Default RE: thanks
Exhaust manifolds get hot ... real hot. If the wires are in the wrong place its easily possible to melt them.
Old Jan 23, 2009 | 05:05 AM
jsawyer's Avatar
Default RE: thanks
Well i was unaware of a valve cover leak and i didnt have the heat shield on so it driped on the manifold and cought fire and melted the wires i spun two rod bearings at the same time it was my lucky day lol. But got the new moter in and running. What have you guys heard about useing a 7 bolt crank in a 6 bolt block ?
Old Jan 23, 2009 | 06:03 PM
Default RE: thanks
Bad f-ing idea.
Old Jan 24, 2009 | 05:04 AM
jsawyer's Avatar
Default RE: thanks
what would be so bad about it ?
Old Jan 24, 2009 | 05:16 AM
jsawyer's Avatar
Default RE: thanks
sorry clicked it twice
