throttle positioning sensor
Old Jan 29, 2009 | 02:52 PM
needsagst98's Avatar
Default throttle positioning sensor
i have a 98 gst and i have still have weird idleing issues. i check the iac motor. i checked all the pins on the iac motor for resistance. then i checked the motor itself with a 6 volt battery. and wetn trough vfaq site and tested it fully. now when i checked the ohms on my tps it came out at 4.67k closed and i adjusted it to .9k like its supposed to according to vfaq. do i need to replace my tps casue its not at 5k ohms like it shoulkd be? also is there any other way to fix my egr valve without bloacking it off ? and if i do have to block it off with it fail emissions?
Old Jan 29, 2009 | 10:19 PM
98gstspy's Avatar
Default RE: throttle positioning sensor
just wondering what type of idleing issues are you having. i have been having some with my 98 also and just want to see if its somthing similar
Old Jan 30, 2009 | 10:39 AM
my idle kinda wodners its on way, my idle is always high. like around 1200 to 1300rpm and sometimes it goes to 1500rpm and then back down maybe after like 10 min of driving. i think my tps was out of adjustment but im going to put my TB back on this afternoon and see what happens then. it could be ur egr valve. thats my next guess
Old Jan 30, 2009 | 02:33 PM
estraw's Avatar
are you sure your throttles just not sticking?
Old Jan 30, 2009 | 10:55 PM
it might be, where would i check for stickyness? thats probably a dumb question. i did spray wd 40 on the springs of the TB with the throttle cable is, and it seemed to help out a little. ill know for sure when i get the tb back on again and ill spray the TB springs agian and see if that helps out or not agian. ill get back to you on it in a day or so.
Old Jan 31, 2009 | 12:56 AM
estraw's Avatar
take throttle body cleaner and spray down the inside of your tb. also check to see if your throttle is adjusted properly (take off the intake piping and look to make sure the throttle plate closes fully)
Old Jan 31, 2009 | 09:35 PM
ill spray it with throttle body cleaner again and ill take a picture and post it and see if its closed enough. as it sits off now. can u adjust the tb plate?
Old Jan 31, 2009 | 10:47 PM
also i need my trans rebuilt. my 1st gear and reverse syncrhos are gone. i have a 98 gst 5spd. does anyone know an average price to get it rebuilt?
Old Feb 1, 2009 | 10:04 PM
should my tps resistence fluxuate when closed? when i open the tb it alwasy goes to about 4.60 to 4.61. but hwne its fully closed it goes from 1.09 all the way to .89. somtiems its like 1.02 and then i open and close it and then its like .93?. is that normal or not?
Old Feb 2, 2009 | 06:23 AM
sometimes its actually cheaper to buy a new tranny rather than rebuild this one. But i would just ask around and compare the difference
