throw out bearing
Old 06-06-2006, 08:07 PM
5Tizzle's Avatar
Default throw out bearing
i somehow managed to screw the throwout bearing, as some of you may know, but just for the sake of money i have right now, is it alright to just replace the bearing, instead of an all new clutch. I want to get an upgraded clutch, and dont have enough right now.
Old 06-06-2006, 08:09 PM
Default RE: throw out bearing
yes i think it would be ok just to replace the bearing. I would inspect the disc and pressureplate though.
Old 06-06-2006, 09:12 PM
5Tizzle's Avatar
ORIGINAL: Sebba
you THINK? well...thank you for the advice. now what would you do if i went out, under your advice, replaced the TOB only, and i totally ****ed something else up because of it?
I dont mean to be a dick, but dont answer a question if you dont know the answer.
Old 06-06-2006, 09:16 PM
Thats fair. Well as long as your disc and pressure plate is in good condition then you should be fine... YES you can just replace the TO bearing.
Old 06-06-2006, 09:17 PM
5Tizzle's Avatar
ok thank you
yeah they should be in good condition. my clutch was grabbing great and everything before the tob went out.
Old 06-06-2006, 09:18 PM
lol i might be 15 but im not ****in stupid
The reason i asked was because you mentiond that the clutch was smoking... or "something from the tranny side"... that sounds to me like its the clutch. That probly put a little wear on the clutch
Old 06-06-2006, 09:27 PM
5Tizzle's Avatar
ORIGINAL: Sebba
I dont know man...from hearing your theories on crankwalk, its pretty hard to take you seriously
Old 06-06-2006, 09:37 PM
hmmm... i was just passing on what i had been told from a very good source.
Old 06-07-2006, 10:05 AM
myself I would replace the clutch too, but thats just me. If I DIDNT have the money to do it, I would find a way. Im big in 'while its apart, fix it right and replace ****'.
Old 06-07-2006, 10:57 AM
ORIGINAL: magnet
agreed. stock clutch is junk if you dont do it now when you get some small mods you will need to so I would find a way to spend a few hundred and just do it right
Quick Reply: throw out bearing
