Throwing a code...HELP!
Old May 3, 2007 | 06:32 PM
tidus10's Avatar
Default Throwing a code...HELP!
P0125 is the code its a 1996 Mitsubishi Eclipse Spyder GS i have therepair manual and it skips over that code, i called me local dealership they said its a dealer only code and they cant tell me what it is... SOMEONE PLEASE HELP!!!
Old May 3, 2007 | 06:33 PM
Dusty Eclipse's Avatar
Default RE: Throwing a code...HELP!
P0125 Coop Fuel Ctrl Insufficient
Old May 3, 2007 | 06:36 PM
tidus10's Avatar
i know that much..what is it though?
Old May 3, 2007 | 06:40 PM
tidus10's Avatar
my car manual doesnt show that code i called teh dealer they said it was a dealer only code..wtf...
In less words, your car has the incorrect A/F ratio.
Old May 4, 2007 | 01:44 AM
tidus10's Avatar
on a different site it said my thermostat was wierding out...
Old May 4, 2007 | 01:54 AM
silvercoupe97's Avatar
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
Also.
P0125 OBD-II Trouble CodeTechnical Description Insufficient Coolant Temperature For Closed Loop Fuel Control What does that mean? This means that the engine coolant temperature (ECT) sensor indicates that the engine has not reached the required temperature level to enter closed-loop operation within a specified amount of time after starting the engine. Symptoms You will likely not notice any drivability problems. Causes A code P0125 may mean that one or more of the following has happened: [ul][*]Insufficient warm up time[*] Low engine coolant level[*] Leaking or stuck open thermostat[*] Faulty coolant temperature sensor[/ul] Possible Solutions The simplest thing to do is to reset the code and see if it comes back. If the code comes back, the problem is likely going to be the result of the above causes (faulty thermostat, faulty coolant sensor, or a low coolant level).
That's for a FORD. Believe it or not, it doesn't matter because your coolant temp (ECUs, not gauge's) will have the same affect if it's not working correctly.
Oh and the thermostat too.
Old May 4, 2007 | 01:59 AM
tidus10's Avatar
http://www.automotiveforums.com/vbulletin/t254394.html
http://www.team-2g.com/mitsubishi-ec...ad.php?t=15892
i'm soo confused...
Old May 4, 2007 | 05:45 AM
Original poster: Evil-IceMan
So for the past like 4 months my car misfires everytime i turn on the car. The number 3 cylinder is the one that misfires for approxitmately 2-3 minutes. Whether cold or warm it does it. Im throwing an engine code (P0125) saying my car takes excessive time to enter closed loop mode and it went into some detail about that number 3 cylinder. I looked this up on ALLDATA and it could be a unch of things.So was wondering if anyone else had this problem, and could help me out some and save me some time. Your help is appreciated!
So yours does the same thing?
Did you read my last post? You're looking too much into this code. Do what I have posted above yours and get back with us.
Old May 4, 2007 | 09:29 AM
tidus10's Avatar
i didnt read teh one you posted above mine we musta posted at the relative same time :-P thanks a lot i have to talk to my mechanic now..
