TIMIN BELT
TIMIN BELT
<IMG src=smileys/smiley19.gif border="0"> you probably bent the valves if it broke when engine was running.Also never turn crankshaft past top dead center or rotate cams unless timing belt is on,you will bend or crack valves and dent pistons.Also,balance shafts must be timed to crankshaft and cams.I have full factory service manual if you need help.
marx88
06-30-2011 03:54 PM
