TIMIN BELT
Old Nov 15, 2003 | 04:45 PM
ALVARADO's Avatar
Default TIMIN BELT
HEY GUYS! I GOTA QUESTION, ON MY ECLIPSE 92 I HAD TO REPLACE THE TIMIN BELT CUZ THE OLDONE BROKE LOOSE, BUT NOW I CAN'T START THE ENGINE. </P>
CAN SOMONE HELPME?</P>
Old Nov 26, 2003 | 10:26 PM
oldmansgs's Avatar
Default TIMIN BELT
<IMG src=smileys/smiley19.gif border="0"> you probably bent the valves if it broke when engine was running.Also never turn crankshaft past top dead center or rotate cams unless timing belt is on,you will bend or crack valves and dent pistons.Also,balance shafts must be timed to crankshaft and cams.I have full factory service manual if you need help.
marx88
Jun 30, 2011 03:54 PM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
pedalon
Jan 6, 2004 02:54 AM
dadandcoach
Dec 1, 2003 08:53 PM
