Timing belt
Old May 11, 2006 | 02:20 AM
B.e.R.a.T's Avatar
Default Timing belt
I have decided I am gonna change the timing belt so I went and got the timing belt, balance shaft belt and the water pump with the gasket. Do I need to replace anything else while I am already working on it????
Old May 11, 2006 | 03:53 AM
My93EclipseGS's Avatar
Default RE: Timing belt
I would check all your belts that run the alternator, ac pump etc. since you have to take them off anyway to change the belt. Also remember when you put the timing belt back on to put a big wrench on the intake cam to get the marks to line up just right or you will be taking the thing apart again like I had to when I did mine.
Old May 11, 2006 | 04:10 AM
B.e.R.a.T's Avatar
my mechanic is gonna deal with all that so I am not worrying about marking it. I will definetelly change the other belts too than thanks for letting me know.
Old May 12, 2006 | 02:37 AM
Joel_CA's Avatar
I definately recommend replacing the hydraulic tensioner at the same time. Now would also be a good time to replace any oil seals that might be leaking. The upper and lower balance shaft seals tend to leak over time. Very easy replacement and the cost for the seals isn't bad either so replacing all of them shouldn't be too much extra.
Joel, Ca
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
