Top leaking......
Top leaking......
My top leaks when it rains real hard, just wondering if anyone changed the rubber lining on the top before. does a leak mean i need a whole new top? where could i go to get it fixed and how much do you think it would cost?
RE: Top leaking......
Where is the water leaking in specifically? If it's just in one spot then it's probably just a whole or small rip. Those can generally be repaired fairly cheap. If it's leaking from all around you may need to replace the whole top. I've heard aroun 2G for that but like I said that's just what someone told me. You could be bold and daring and try to refabricate it yourself!
My top leaks too on the driver and passenger side at the same spot. Its right where the top meets the windshield, they meet ok but its where the window comes up there is a little separation it looks like im not sure what to do but it only leaks when i turn or brake......someone please help!!!
Hey, I have had my car for about two months now, it leaks in the same spot that yours does, right where it meets on both sides of the car. I have tried everything I can think, even silicome but nothing seems to work. The water runs down from somewhere from the back part of the top I think. The best I can tell you is get a water hose and see if you can't find out where it originates from and I hope your is not as bad as mine, I gave up and use towels when it rains. The only place i can seem to find the top is at the dealership and that is pretty expensive for all the lining and stuff. If you do find out where it is coming from please let me know or if you find the top somewhere else. Later
