Topmount manifold??
Old 08-30-2007, 02:58 PM
jason clipse's Avatar
Default RE: Topmount manifold??
just for looks....and also i think it says in there that all the stuff to re route the coolant and stuff is included
Old 08-31-2007, 08:43 AM
RCJr9186's Avatar
ORIGINAL: jason clipse
i'm REALLY trying to look at the bright side. and i guess the bright side would be that he didn't just put
x2
Old 09-01-2007, 06:12 PM
Actually,it's for fitment issues.A lot of bigger turbos have a hard time fitting down in our bays. It's alsofor heat. A lot of true 3" downpipes/ o2 housings come too close to the alternator and fry it, same with the oil filter. This gets the dp and o2 further away from these parts. There are other benefits too, these are just a few.
Old 09-03-2007, 07:13 AM
you gotta think of how close the turbo is to the block, which becomes a clearence issue after you go so big, and also i noticed on my 1g the 3" exhaust is gonne end up about 1/4" away from the oil filter, thats a really bad thing to heat up -remote mount for me....
Old 09-04-2007, 07:32 AM
ORIGINAL: TSG59_Steve
true except that you CAN fit the 35r in the eclipse pretty easily and alot of companies already make a normal kit. Its the same thing with the EVO. They first have the normal mounted 35r kit and then they came out with the top mount kit. I really dont see much of a gain for fitament. I still say its 90% for looks.
Old 09-04-2007, 07:48 AM
ORIGINAL: TheEngineer
so its for looks. because the turbo is placed further away from the radiator than it would be with a regular manifol... look at my 50trim it almost touches same with the wastegate. cause top mounts on I4 FWD\AWD looks dumb anyway unless its like a 37r or bigger on there
elecbluegst
02-09-2006 03:57 PM
jeantheman
04-07-2005 01:21 AM
sigma_turbo
01-11-2005 03:48 AM
LowCloud
01-05-2004 05:25 AM
sidewaysjack
11-21-2003 02:49 AM
Quick Reply: Topmount manifold??
