???? total confusion ????
Old Feb 12, 2005 | 07:15 PM
get435's Avatar
Default ???? total confusion ????
Ok my car was throwing a error code for the cam pos sensor and/or the crank pos sensor i thought it was the CPS so i replaced it and it turned out that it was a recalled part had to replace part of the harness as well so all was fine and dandy and the check engine light went away. Drove like a dream than the other day "about a week after the new CPS was installed" it died and wouldnt start would turn over but not start. to i took off the negitve batt connection and reset the computer and it started fine no problems. but it has dont it three times in the past week and a half. DOSE ANYONE KNOW WHAT THIS CAN BE ?
Old Feb 13, 2005 | 11:41 PM
customizedrides's Avatar
Default RE: ???? total confusion ????
Check your timming maybe...You need only three things to start a car. Air/fuel mixture, spark and compression. Check those three things and you should find your problem.
helicopterred
Jul 3, 2009 11:43 AM
sentakuki96
Jun 7, 2008 07:44 PM
unfaded451
Oct 1, 2007 10:59 AM
jasper hater
Apr 2, 2006 05:28 AM
